Ten Roofing Maintenance Tips for Lasting Roofing
Top Roofing Tips to Remember
1. Homeowners beware. A great time to start with any roof appraisal is prior to your closing date. Getting a specialized roof inspection prior to that future home is officially yours will save you a good deal of time and costly repairs in the future, which can also be a plus if and when you decide to sell your new home.
2. Trim troublesome trees. When admiring your home and surrounding landscape, it’s important not to overlook leaning limbs seeking companionship with your roof as they can scratch and gouge your roof materials. To prevent damaging or puncturing your shingles, simply Cut back and remove any limbs Having too close to your roof.
3. Gutter cleaning removal of leaves. Clean the leaves and other debris. In addition to bothersome limbs, leaves and other aspects can clog your gutter system and cause water to backup into the attic, living places or behind the fascia boards. To ensure your drainage system is free flowing, it’s recommended that you clean your roof at least twice per year. Also, be on the lookout for sagging gutters or damaged drain components and repair or replace as needed.
4. Ensure the roof is built to breathe. Without proper ventilation, heat and moisture can cause sheathing and rafting to rot, roof materials to buckle and insulation to lose effectiveness. This will cause your overall roofing system to be ineffective.
5. Include insulation. The best way to achieve appropriate ventilation and good airflow is through proper insulation. To protect a house from heat gain or loss, it’s ideal to include a gap-free layer of insulation on the attic floor and a vapor retarder under the insulation next to the ceiling to stop moisture from rising into the attic. Having open, vented spaces that allow air to pass freely with at least one inch between the insulation and roof sheathing is also ideal.
6. Check for attic aftermath. In addition to having a well insulated attic, it’s a good idea to check for water stains and weak shingles after a heavy storm.
7. Safeguard against streaking. Make sure to pay close focus to the color of your roof. Roof places, generally the northern part, exposed to shade during long periods of time in moisture will eventually become streaked with mold, algae or even fungus. And if left unchecked, will eventually deteriorate the roofing material shortening the life of the roof, which could lead to leaks and other signs of trouble.
To cut the mold situation completely, it’s The perfect idea to install zinc strips, like Shingle Shield Roof Protector strips, along the ridge of the roof. They are precision engineered to provide environmentally safe (EPA approved), long-term (average home 20 years) roof protection from fungus, moss, mildew or algae attack.
8. Damaged shingles on residential roof. Check for signs of shingle damage. Being exposed to everyday wear and tear from various aspects can cause shingles to become dilapidated and get torn off, making a roof structure and interior space vulnerable to water seepage and rot. Thus, it’s highly advisable for homeowners to examine roof coverings each year to ensure their integrity.
9. DIY roof repairers. Those daring enough to try roof repairs themselves need to bear in mind that it’s dangerous up there. it is advisable to stay on a firmly braced ladder equipped with rubber safety feet when possible. If you do decide to walk on the roof, it’s best to wear rubber-soled shoes to prevent slipping.
10. Quality roofing estimates. When repairs go beyond a DIY project, you should make sure to do some homework prior to calling in the cavalry. it is advisable to get at least two estimates so you can determine the best combination of quality and price. Think long-term and not cheap when choosing a roofing company and it’ll save you a good deal of repair costs in the future.
Bottom line: it is important to remember the roofline. Taking a top-down approach with yearly inspections and utilizing these quick tips and tricks will help preserve and protect your interior living space for many years to come.
