Best 10 Self Storage Tips
The great moving or cleaning day has come and you’re prepared to move into your self storage unit. Undoubtedly you have anticipated for the basics, like touring the facility, getting your exclusive key code for the gate and purchasing a lock for the door; but there are a couple of tips that may come as a surprise to you.
Our experienced team of self storage professionals have a ton of knowledge they have gained over the years. They’ve compiled their Greatest ten Storage tips you may not have known to help you make the most out of your storage experience.
AND THE TOP ten ARE:
Recommendations for Storing your items in a self storage unit
1. Utilize dryer sheets to keep insects and spiders away. Put them in all corners and boxes especially by the front of the unit. The sheets will also keep your items smelling fresh! (Be sure to replace the dryer sheets monthly to maximize results)
2. Utilize breathable materials like cardboard for storage so that moisture isn’t trapped. Never store your items in plastic bags or other airtight containers.
3. Make a passage between boxes so you can easily reach your stored items. Sometimes you will need single items from the unit, with an passage, you won’t have to move all of the other boxes out!
4. Put charcoal in a saucepan and leave it in your unit. It will help absorb moisture.
5. Make the most use of vertical space by stacking boxes of the same size and storing couches on their side. Utilize shelving along the sides of your unit for even more space and organization!
6. Utilize mattress covers to keep mattresses and box springs dust-free. (We have them in all sizes). Or you can use 2 fitted sheets to cover the best and bottom to keep the dust away.
7. Leave a small space between the walls and your boxes. It prevents mold and allows for ventilation. Also use our wood pallets to keep your boxes off the floor for further ventilation.
8. While many items you store will be temperature resistant, be cautious with very sensitive items like electronics. Don’t store them in extremely cold weather. Freezing temperatures can ruin electronics like flat screen TVs and can even wipe the hard drive of laptops and computers! If you remove the items in the cold, allow them to sit for 48 hours in your heated home before plugging them in to prevent plastic components from cracking.
9. Drain all fuel from leaf blowers, lawn mowers and other gas-powered machines. When storing your car, make sure the gas tank is either completely full or completely empty to avoid condensation!
10. Pack your truck in reverse from how you would like your unit packed. A little planning goes a long way!
These are just a couple of tips to get you started. Be sure to ask your Self Storage manager for more tips and tricks to make your storage experience the best it can be!
